danimal53 wrote:
danimal53 wrote:
Muddydogs wrote:
Since RV'ers got away from 12 volt TV's and generally use regular TV's and inverters some manufactures stopped putting 12 volt plugs into trailers. My toy hauler didn't come with any. Its an easy install where you can usually hook into an existing 12 volt light or switch wiring. I put one in the main living area using the wiring running to some under cabinet lights and another in the bedroom where I pulled power from the light switch. In both cases the trailer wiring is 10ga so its big enough to powder a 12 volt plug and a couple led lights. Depending on what you want to charge you might want to install a single or double USB plug instead of the standard 12 volt socket. I put a 12 volt socket in the living area but all it ever has plugged in is a USB adapter so when I did the bedroom I just put a double USB plug in. Have a couple of each might be a good idea.
yea it appears i dont have 1. great advice on the USB plugs, I will likely do something like that near the dinette, maybe a 12v on the outside. just seems weird there is no way to plug anything in when on battery power, i guess its mod time
the main reason i ask is i have a 12v tire inflator which ive had for my jeep, it has a 10ft cord. 10 feet not enough to reach the TT tires if I needed to add some air. So i suppose i should at least add a 12v outlet outside. Unless someone has a different suggestion?
I'm thinking od doing the same thing. My previous trailer had a 12V at the outside radio, my new one doesn't.
