bdhound said, "the main reason i ask is i have a 12v tire inflator which ive had for my jeep, it has a 10ft cord. 10 feet not enough to reach the TT tires if I needed to add some air. So i suppose i should at least add a 12v outlet outside. Unless someone has a different suggestion?" be careful using an existing 12V outlet to power a tire inflator. The inflator uses quite a bit of current. The fuse on my 12 volt outlet is only .5Amp which blew in an instant when I tried to use my inflator.
I added an additional outlet. Check your power converter; it may have an unused fused 12V outlet. Mine did, and that's where I added a dedicated 12V outlet with its own (larger) fuse.
