- ajridingExplorer II
Kach wrote:
Our new trailer came with a Norcold 12v 8 cu ft fridge. Seems pretty nice for an entry-level trailer like ours. I’m running 2- 6v interstates with about 100 and change usable aH.
... I’ll be getting some solar this summer, bu here in the PNW we can sometimes be in the trees so we need a backup plan. When we ski there is only a few hours of direct sun (on sunny days) but it would still probably help. Also skiing, we tend to run the generator a lot anyways watching movies etc.
Get solar asap. It is great u can go 3 days on batts, but you are accelerating the damage to the batteries by not putting at least some charge on them during the day. Everytime you run the batts down they die a little. In the summer with good sun you should be able to have the batts charged back everyday. Do your power things early so you can go to bed with a full charge; charge phone or laptop in the morning so panels can resupply the batts still.
Eventually those same batts will go one day before they are dead. - Boon_DockerExplorer III:)
- StirCrazyModerator
Boon Docker wrote:
StirCrazy wrote:
Boon Docker wrote:
At 1.1 amp your fridge uses about 105-110 ah per 24 hour period. I wouldn't call that real good for boondocking.
at 1.1 amps that should bc 26.4 ah in a 24 hour period.not 105-110
Steve
Yes, 26.4 amp at 120VAC, but we are talking about 12VDC while boondocking.
1.1 amp at 120VAC = 11 amp at 12VDC
A would love to have a residential fridge that draws 1.1 amp at 12VDC.
Ahh you should have mentioned that last part in the original post, would have saved a old guy like me some confuision haha.. - goducks10ExplorerI have a GE 12V only RV fridge in my TT. I also have 400W of solar and 4-6V GC batteries. With decent semi to full sunny days and being in the sun about 60-70% of the time I can go 3 days without running the gen. Thats also using most all 12V stuff available like the TV, Dish, LED lights water pump, etc with no furnace.
The cool down and temp stabilization are heads above the Norcold we replaced.
We aren't winter campers and if it's going to be cloudy with rain we usually stay at elec sites so the fridge is then running off the converter.
I will never go back to an absorption type fridge. I paid $950 and another $40 for a 3 year warranty. I gained 2+ more cu.ft as well. It was snap to install, needs no inverter like a 120V does and is quiet enough to not be noticeable when the compressor's running.
It was super easy to install and wire up.
Most all 12V fridges are made in China by the same company either re-branded or with some design changes. - KachExplorerOur new trailer came with a Norcold 12v 8 cu ft fridge. Seems pretty nice for an entry-level trailer like ours. I’m running 2- 6v interstates with about 100 and change usable aH.
It is definitely a big draw on the system. I find we’re bumping on the lower end of power in the morning, but I usually can’t shut everything down to get an accurate reading. We made it in the mountains for 3 nights with the fridge and furnace going. The fridge has a night mode that makes a big difference (I forget to switch it on about 1/3 of the time). We definitely need to run the generator daily to make it winter camping.
If I had room I’d add another pair of batteries. I’ll be getting some solar this summer, bu here in the PNW we can sometimes be in the trees so we need a backup plan. When we ski there is only a few hours of direct sun (on sunny days) but it would still probably help. Also skiing, we tend to run the generator a lot anyways watching movies etc. - rbpruExplorer III have a 12v/gas/120v unit in my pop-up and a gas/120v in my TT. Both units work as anticipated.
I have no desire to shake, rattle and roll a household compressor down the road, nor do I want to be dependent on 120 volt availability.
Other, however find this perfectly fine for the style of camping they prefer. - Boon_DockerExplorer III
Steve
A would love to have a residential fridge that draws 1.1 amp at 12VDC. ajriding wrote:
Reisender wrote:
ajriding wrote:
The
Never use a household refrigerator unless u plan to park permanently.
Why not.
The Danfoss compressors are just more efficient, and also they do not need a spike of electricity to start up, they have a slow-start process. It can be difficult for battery to provide enough surge of amps to the electric powered devices to get the compressor to moving.
These DC fridges are made specifically for the needs and to be used by DC power supply as on Jeeps or RVs. I think they first got popular in the off-road vehicle camping market (jeeps and other 4x4 trucks), but the RV market quickly jumped in too.
The DC fridges seem to have more adjustments aimed at conserving battery than a house fridge would.
Maybe there are some household fridges that are more efficient than other house fridges, but I doubt they beat the DC ones, and I would not be so fast to believe they are as good as the DC ones designed to conserve as much battery power as possible while camping. Also, with a house fridge you will have to use an inverter, which itself is not efficient in that it consumes power/ waste some power to do its thing, so you are wasting amps that could be better used.
In the end the DC fridge might be a little more expensive than that $100 walmark one,but so are your batteries. Running batteries low is what kills them, the less power you need the longer a life the battery will have.
My personal fridge is a 2-zone one. I can control the temp individually and even turn one side off. So, when boondocking and I use up all the frozen good I just turn off the higher-amp-draw freezer and run only one side as a fridge. This saves a lot of power compared to always running both fridge and freezer side. Some trips I do not even need the freezer so just use the one side.
If I do plug into shore then the fridge automatically switches over to the shoreline power instead of battery, so that is nicer than having to go turn off the inverter and switch some old house fridge over all the time.
IF i run Air Cond at night then I will not let the fridge use AC power so this saves gas as gen only holds enough gas to make it through the night (10-11 hours) just for AC, Fridge load would shorten this.
Also, if I would have pointed this out 12 months ago you would think Im kooky, but if SHTF then this DC powered fridge might make life a little easier than a household fridge... AND S did HTF in some places already, the World did not end, but S was flinging around the room for a time period.
All good points, but 21 cubic foot models Dan Foss models don’t seem to exist yet. That would be an obstacle for the big pusher crowd.
Cheers.- ajridingExplorer II
Reisender wrote:
ajriding wrote:
The
Why not.
Also, if I would have pointed this out 12 months ago you would think Im kooky, but if SHTF then this DC powered fridge might make life a little easier than a household fridge... AND S did HTF in some places already, the World did not end, but S was flinging around the room for a time period. - JRscoobyExplorer II
MFL wrote:
bob_nestor wrote:
(There were absorption type refrigerators made for household use years ago. As a kid it used to be my task to refill the kerosene tank on ours monthly.)
Good post earlier in it's entirety, but above has me thinking Bob was born around 1921-2??? :)
Jerrywanderingbob wrote:
We had " absorption type refrig in the 50s . One ran on propane and the other ran on kerosene . As I remember the kerosene had a wick that my mom had to 'trim ', what ever that meant to a five year old .
Dad bought a used absorption fridge the summer before I was born, '49. In '58 bought new house and first electric fridge. Re-jetted it to burn natural gas, put it in basement for beer. Sometime when I was across the water in green clothes it was converted back to propane, and moved to a cabin that was past the end of wire. Sometime in the late '70s/ early '80s They got power to the cabin. In the late '90s I saw that fridge on the porch of the cabin. (the BB mark started a story) "Does that still work?" Yes, use for drinks. And if we leave food here when go home we put it in there incase power goes out.
BTW, before electricity was domesticated well off people had a icebox in the house. Ice was delivered door to door. (Many early trucking companies had names like JOHN DOE and Sons, ice and coal Use same truck depend on season) The plants that made that ice worked on absorption.
44,030 PostsLatest Activity: Jan 20, 2025
