nwbearcat1998ExplorerMay 31, 201512v water pump intermittentHello, I own a good 004/keystone cougar and throughout the day, the water pump runs for almost a second with none of the faucets turned on. I cannot find any leaks around the faucets that are vis...Show More
Dakota98ExplorerMay 31, 2015If you have an outside shower, check the valves to make sure they are completely closed.
Related ContentWater PumpWater Pump Failure Traveling To The EclipseWater pumpSlow water/noisy pumpwater pump
