nwbearcat1998ExplorerMay 31, 201512v water pump intermittentHello, I own a good 004/keystone cougar and throughout the day, the water pump runs for almost a second with none of the faucets turned on. I cannot find any leaks around the faucets that are vis...Show More
mhardinExplorerMay 31, 2015I had the same problem on my Sure Flo pump. I bought a repair kit and replaced the leaky diaphragms. Problem solved. Easy fix!
Related ContentWater PumpWater Pump Failure Traveling To The EclipseWater pumpSlow water/noisy pumpwater pump
