JoeChiOhki
Aug 17, 2018Explorer II
joerg68 wrote:
They are commonplace here... I am not aware of a metal version, nor would I want one. Too many +12V connections in close proximity...
The pins are very close together and to wire one of them can be challenging. They also only accept fairly narrow wire gauges, so they are not well suited for higher charging currents. You can combine the pins for +12V continous and +12 ignition switched for twice the gauge (and current), but then you are no longer using the standard layout.
They are the one and only official connector for travel trailers here. There is a similar 7 Pin connector for utility trailers, and adapters between both - that is about all. There is no dedicated single systen for TCs, but the 13-Pin connector is pretty common. I have one on my Northstar.
Other than that, they are reliable connectors, connections are secure, and they are sort of weatherproof. But it does not hurt to keep an eye on the back side of the connectors once in a while and use some sort of anti-corrosion agent to keep the moisture in check - WD40 or something better.
When done right, they last many years with minimal maintenance. We don't really like them, but they work OK.
How do you wire them for an american truck? If you use the official european layout for the connectors, they have separate pins for turn signals and brake lights. While the truck's turn signals and brake are combines in one bulb. They have an extra pin for a fog taillight, which you don't have.
Is there a standard US layout? Of course you can use the 13,pins like you want - until someone wants to plug that plug into a receptacle thatvis wired differently...
There is no US 13 pin out plugs of any kind, I'll need to import the parts to make it work.
My goal is to reduce how many holes I have to cut in the side of the camper for new connectors and how many new holes need to be made in the bed of the truck.
I found a couple caravan shops that sell an aluminum version of the plug, but none of them ship international.
I use a semi-truck lift gate plug specifically for the charge wires 12+/-, the other stuff is all small gauge stuff, signals, running lamps, backup camera, intercom.
My end goal is ideally to only have two cords to hook and unhook from the truck and camper.
I'm hoping for a metal socket, because plastic doesn't hold up well on a truck that gets used for hauling things besides a camper.
The European plug wire color scheme for the important stuff (Signals, Running Lights) is identical in color to the US, so its a one to one match for those three wires (I won't be using the separated out stop wires in standard).
The rest of the plug will be getting custom wired for the intercom unit (Six wires, which originally used what looks like an outdoor rated DIN plug), and the backup camera (3 wires).
burningman wrote:
I would use a standard pattern 7-pin and a second connector for your custom stuff.
That saves potential hassle if you ever have to move the camper with a different truck.
This combo is already a custom setup, down to the running gear on the truck itself. I already use a 100amp rated Lift gate plug for a panel van for the 12 volt +/- and currently a 4 pin round for the signals and running lamps.
If I change trucks, it would be just another of the same vintage, at which point I'd be moving all of the custom wiring and charging setup over to the replacement truck.
I have multiple wires I have to contend with.
The charging portion is already taken care of. That leaves me with Running Lights, Turn Signals and the Reverse light (Wasn't wired in originally, being re-added with the new camper)
That's Four wires.
The Intercom unit uses Six.
And the Backup Camera uses three (two leads for the video signal and one for the camera's + power lead).
That gives me a total of thirteen wires. Using standard American connectors, I would need to have three plugs on the camper total (One for the camper lights and Camera, one for the intercom, and the already existing charging plug.)
That's why I was curious about the Jaeger plugs, as I would only have two umbilicals to deal with and one less potential leak location in the front wall under the cabover.
44,056 PostsLatest Activity: Jan 12, 2020
