Second_Chance
Apr 19, 2016Explorer II
From what I understand, the max towing packages are different than the max payload packages. You would need both to even consider pulling a fifth wheel with a 1/2 ton truck. You'll run out of capacity on the rear axle with the pin weight before anything else. You can never have too much truck.
Rob
Rob
