JIMNLIN
Apr 20, 2016Explorer III
jserv61 wrote:
Has anyone had experience with this truck? We need a truck to pull our 9800lb 5 th wheel? It was a recommended option from a couple of dealers. We would only need the truck to pull the 5 th wheel, maybe once or twice a year. Mostly the truck is needed for everyday transportation. Not sure whether to get a 2500 or 1500 with pkg.
I'll repost your question.
The NHT package from GM for their 1500 trucks is the highest package for towing. You get a 7600 GVWR with a 4600 RAWR which will be short on load carrying ability for your 9800 lb 5th wheel trailer which may have 2000 lbs pin weight. Now add a 200 lb hitch and another 100 lbs over the rear axle and your looking at 2300 lb load. The truck may weigh 2700-2800 lb on the rear axle = 5100 lb on the rear axle. Severe overload condition
I would look at a 250/2500 truck. They're good for around 3000-3200 lbs on the rear axle and built to tow/haul day in and day out but still make a good daily driver.
