transamz9
May 16, 2018Explorer
I believe I would check into a different mechanic. 2002 with 100k miles more than likely just had a corroded pin or two causing the ECM to appear be bad. I've fixed two of them by simply unplugging, spraying and plugging back in. Condensation coming in the cab is cause by debris getting in the cowl. Seals drying out and leaking will happen on any of them that sit as much as that 2002.
