GordonThree
Nov 16, 2015Explorer
speedy72vega wrote:
Any thoughts on the fresh water drain tube? Should I put some kind of insulation over it just in case?
My trailer also has a drain tube for the fresh water, maybe sticks out 3" from the belly. the valve for the drain is inside the cabin of the trailer, so its just an empty tube sticking "outside" - nothing to freeze as long as the heat's on inside.
where is the valve for your drain, is it inside or outside your trailer?
44,066 PostsLatest Activity: May 13, 2026
