ZeeLet50
Nov 16, 2015Explorer
If its like my passport, the cap is the valve. When you unscrew it water comes out. I would try to put some kind of insulation over that hose and hope that the warmer water in the tank helps keep it from freezing. other option is to install a valve as close to the top of drain hose or put one inside the trailer. The later would be a pain as I assume your water tank is under the bed and pump and fittings are beneath the side nightstand. This involves removing the top cover to access.
44,066 PostsLatest Activity: May 13, 2026
