specta's avatar
specta
18" tire question - ANOTHER UPDATE
Was in this forum where someone was taking about 18' tires with a 4000lb load rating??
Trying to find them.
UPDATE BELOW
The pick up some nice size ricks between the lugs when you leave the pavement and when you're back on the road they can bang pretty loud when they hit inside the fenderwell.
Other than that so far so good. :)
  • Nitto Grapplers 295 70R 18. 4080 lbs@ 80 PSI. Load E
  • If you are going to buy new HD rims, then I would only consider 19.5 wheels and tires. You can exceed 4000# without getting oversized tires that will change your speedometer, gearing and AT shifting. You can stay at or near the original diameter specs. The tires will also wear very well with a good safety margin. Another advantage is the more vertical profile which helps avoid sidewall damage when driving off road.
    If you already bought some fashionable aluminum wheels, I would be absolutely careful about the load rating. Many wheels are designed for looks and have relatively low load ratings.
  • Cooper Discoverer AT3XLT 4080 lb. load cap. tire in the size you're looking at.
    A little less than Toyo
    https://www.walmart.com/ip/COOPER-DISCOVERER-AT3-XLT-All-Season-LT295-70R18-129S-Tire/847425147
    https://www.amazon.com/Cooper-Discoverer-All-Terrain-Radial-Tire-295/dp/B07DN9JXMW
  • stupid question, are the wheels rated for 4K?
  • Grit dog wrote:
    285 and 295 size get into the upper 3s and up to 4k.
    These are most likely what I'll be getting.
    I just whish I didn't have to go soo tall. :(
  • cheftim wrote:
    I got a lot of help with them from this awesome forum. Went with Toyos.
    https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/30205105/gotomsg/30254550.cfm#30254550
    Thank you, that's what I was looking for.
    I just bought some 18" wheels and I need to start looking for tires.
  • 285 and 295 size get into the upper 3s and up to 4k.
  • I got a lot of help with them from this awesome forum. Went with Toyos.
