pirlbeck's avatar
pirlbeck
19.5 tires again-more input needed please
I am looking for some 245/70R19.5 load range G or H tires for a 4X4 3/4 ton pickup that mostly will see highway miles. Some of the criteria are as follows.
1, Must be hi quality/reliable.......this truck will mostly be used for long distance vacation trips with a truck camper on it and it may end up on an Alaska trip in a couple of years.
2, As it will mostly be long distance, highway miles, I don't want tires that would be objectionably noisy.
3, Very rarely will be off road, but an all terrain type tread may be OK, so long as they are not real noisy and wear decent.
Right or wrong, but due to the local dealer and an Alaska trip and other longer trips we have planned, I have pretty much decided to go with Michelin's as I want a very high quality tire to lessen the odds of tire problems.
I have kind of narrowed the choices down to the following 3 options.
Michelin XZE tires all the way around. These are a straight tread steer tire which concerns me some as I am not sure what we might run into road off/road driving if we do get to Alaska someday.
Michelin XDS2 tires all they way around. These are a mud/snow rated tire. The concerns with these tires are noise at highway speeds and possibly less tire life then the straight steer tires.
Michelin XZE tires on the front and Michelin XDS2 on the rear. This combination limits the rotation options, but other then that it may be the best compromise for noise, traction and tire life.
Anyone have any experience with this size tires in different combinations?
Thanks!
