Tamnative
May 28, 2015Explorer
stevenal wrote:
Even if rings were added, don't you still have the problem with the flat Ford lug nuts seating properly against the rim? Can't see what purpose the rings would serve.
You don't use the Ford lugs Vision will supply you with the ones you need.
I just got a message back from Vision and the wheels are hub centric.
For a Ford 2005 F-350 (and many other years) as explained to me by a Ford engineer(retired)it is important to have this,when the truck was designed it was part of what they used to figure the load handling.
You want the hub to hold the weight not the lugs as was used in the past.
