ticki2
May 28, 2015Explorer
Tamnative wrote:Bedlam wrote:
The Visions are lug-centric and use tapered nuts instead of the OEM flat. We had no issues with 7000-8000 lbs on my 2005 F250 rear axle while using the Vision rims and properly rated tires.
This is the email I got and yes they do use tapered lugs.
Jeff
Those are hub centric hope this helps have a great day
cid:[email protected]
Thanks
Misty Newton
3512 6th AVE SE DECATUR AL 35603
LOCAL 256-351-2459
TOLL FREE 800-633-3936
FAX # 256-260-1259
WWW.VISIONWHEEL.COM
[email protected]
Let us know when you actually try one . From what I've read all the Vision wheels use the same hub bore whether for GM , Dodge or Ford , which all have different hub sizes . It could be that they are sized for Fords which have the largest hub .
