Bedlam
Jun 05, 2021Moderator
Torklift offers a truck frame mount for batteries or you can add additional batteries forward of each wheel well. Using an Anderson connector between truck and camper will give you sufficient flow while making connections easy. Run heavy gauge welding cable between the truck battery and additional batteries using breakers at each battery connection if something shorts.
