JoeChiOhki
Jul 30, 2022Explorer II
Tank if I recall is in the step up to the cabover.
Remove the staples/screws that hold the front wall of the tank step in place, carefully separate the paneling from the frame behind it so you can find the anchor points for the frame.
Remove anchors, remove front step/tank compartment wall. Disconnect all plumbing connections to tank (Most should be hose clamps), remove tank.
Replace tank, its polypropylene plastic and its **** near impossible to mend, reverse process to rebuild step, avoid drilling into tank in future.
