bigfootford
Nov 17, 2016Nomad III
I have a 94 f250 super cab 460 2wd... I put 19.5's on it... Vision rims.. So I do not see why you can not do the same.
Our weight with our LOADED 9.6 bigfoot camper and without is:
Unloaded:
F 3160
R 2680
Loaded:
F 3400 Dif: 240
R 6550 Diff 3870
19.5 tire spec 4500 x 2= 9000 lbs. My weight margin is over 2000 lbs for the rear.
To put 19.5's on the front you have to do a little removal of the front bumper for the tire to clear.
I have only Air bags on the rear. Running 40lbs each.
Almost 200,000 traveling with this camper on 2 ford f250 super cabs... 89 and 94.
My brakes work just fine with the camper on... Even towing 2000 lb trailer or towing a 2000 lb toad.. Samurai or 69 VW baja
Jim
Unloaded:
F 3160
R 2680
Loaded:
F 3400 Dif: 240
R 6550 Diff 3870
Jim
44,070 PostsLatest Activity: Jul 11, 2026
