Your cammper is BEAUTIFUL I have the same model I believe. Is yours fully self contained? Bathroom with shower, toilet and sink? And does it have a built in propane generator? Mine has all that stuff only missing a microwave. And mine is in a little rougher shape. But still very usable. I use it every weekend still. The only complaint I have about it is the generator has an issue running the A/C I can get it to run the A/C if give it some extra throttle while someone else turns the A/C unit on at the same time. I do not know if that is an issue with the generator or if the A/C compressor is just demanding too much power on initial startup. Do you have that issue with your rig? Any input or ideas you may have on this would be very welcome and extremely appreciated. Have a blessed day. My name is Mike by the way.
Hopefully you get a response, but this post is 7 years old.
