Jpetrocik's avatar
Jpetrocik
1999 Terry Ultralite 25R Lift
I am looking to lift my trailer. Right now it has maybe 6" of ground clearance and I have bottomed out way too many times. This last time I damaged the back end pretty good. Anyways, this trailer has a torsion type axle, which I have never worked with. I would like to add 4-6" lift by using steel tubing. For the people who have done this, can you give me any pointers?
Thanks
  • Thanks DavidP
    A friend of mine is a welder and is willing to help. I didn't expect it to be much trouble. I just want to make sure the axles stay aligned well
    I'll post pics when I get around to doing it.
  • I would weld in 3-4 inch mounts where the torsion axle currently bolts to the frame. You would then simply bolt the axle to the new mounts. A good weld shop could fabricate the new mounts and weld them in. Ensure all mounting holes in new mounts are oblong to allow proper alignment. Your other option is to cut off the current brackets on the axle and weld in longer ones. Adding a lift to a torsion axle is very easy, especially if you can weld.
