Bull_Gear
Sep 12, 2017Explorer
1st post: Can I mount a TC in a military truck bed
Greetings all.
I'm currently wanting to ditch my bumper pull toy hauler and get a big TC. Problem is, I need to have my truck all set up before I can go after one and I can't seem to find any TCs to look at close by. There are no local dealers, either. So, I thought I'd just ask for some advice here.
The truck is a crew cab diesel F550 so weight is not an issue (10K payload). HOWEVER I am running a "custom" bed. It is the bed from an M105 1-1/2 ton military cargo trailer.
The inside dimensions of my bed are 110"L x 74"W x 18"H. Wheel well width is >48".
-Can anybody foresee any potential issues if I try to set an 11-12' camper in that bed? From what I can gather, it looks like it should physically set in there.
-I'm wondering if I will have a center of gravity issue considering the length of that 9'+ bed. I'm afraid my axle may be too far forward relative to the rear of the bed. I'm currently at about 52" forward. The COG of the big Lance TCs are only 39" forward. Where is the rear axle centerline in relation to the back of a normal 8' bed? Need I be that concerned with a crew cab F550 or will it be a deal breaker?
-I'm thinking I will need to fabricate a front stop of sorts (or toolbox, etc) for the front of the camper to bear against. I'm assuming that structurally they are not built to bear against the rear stepdown.
-Also wondering about tiedown locations on the camper. I assume they are on the outside edges of the camper, but where are they typically located front-to-back. I'm wondering if I can use the existing lifting loops for tiedown points. The bed is hard mounted to the frame so they should be strong enough.
FYI I am currently considering a Palomino Winter Creek 115RS if that makes any difference.
Any help is greatly appreciated. Thanks.
