BubbaChris
Jun 21, 2014Explorer
That cargo capacity is used by; you, your wife, your kiddo, your dog, and everything inside your QX, PLUS the tongue weight of your trailer.
If you figure up to 15% of your total trailer weight should be on the tongue, then your real capacity is is probably under 6,000 lbs. That means the 28RL is likely out of the safe range. You may need to stay under 20-22' in size.
44,064 PostsLatest Activity: Apr 11, 2026
