rburkeExplorerApr 17, 20232 outlets in GFCI path not workingI have 2 outlets controlled by the GFCI that are not working and 2 that are. In the kitchen. there are 2 protected outlets, one works and the other doesn't and the outside receptacle does not work. ...Show More
LatnerNomadApr 17, 2023open up each outlet and check all the connections visually and with a meter, you'll find the problem eventually.
Related ContentNo power on outside GFCI outletAdding power outlets in slide with no wiringgfci outletElectrical outlet issuesSmoking GFCI outlet
