nickthehunter
Apr 17, 2023Nomad III
CA Traveler wrote:I’d be willing to bet every outlet you have ever encountered was wired in parallel.Latner wrote:You may also find that the outlets and not all connected in series but rather some are connected by a parallel branch wiring.
open up each outlet and check all the connections visually and with a meter, you'll find the problem eventually.
OP: did you check all the breakers? Is it possible the two outlets that don’t work are on a different circuit?
