JRscooby
Apr 17, 2023Explorer II
Grit dog wrote:Latner wrote:
open up each outlet and check all the connections visually and with a meter, you'll find the problem eventually.
I’d start here.
Unless you locate another gfi somewhere that’s popped.
Here is the reason I don't like answering 120V questions on the internet. I do not know anything about the OP's skill set.
OP, the place to start is at the post. Unplug the cord so you know there is no power then pull the outlets to inspect the connections.
