needgas__
May 18, 2014Explorer
!2 volt Electrical issue. Please help
Hello all, Not sure if I have a big problem or I am overlooking something. Here is the problem. When running on 12VDC power (Battery or TV power) my 12VDC system does not run. Water pump, slide motor, nothing. Battery is completely charged and has good capacity. When plugged into 120V, everything works. This tells me the converter is supplying 12VDC. There is a junction block on hitch frame about 2ft from the battery. This is the connection where converter and battery come together. Is this a Diode or just a junction? It is a little corroded and I will be working on cleaning this while waiting on responses. Has anyone seen this issue? Thanks for your help.
Bob
Bob
