monkey44's avatar
monkey44
Nomad II
Jun 27, 2020
2002 Ford Diesel 7.4 ??
Any information on this engine to share?? Thanks
2002 Ford Diesel 7.4, sits in a Xcab LB SW...
  • I own a 7.3, great motor, that being said find something 2011+ with a 6.2 v8. If it is for a business, uptime and maintenance matter at the end of the month, not towing ability.
  • Keep in mind the rest of the truck is going to be old and will require maintenance as well. For me I've got a good mechanic and parts are inexpensive, others might not want to deal with any issues that may pop up from time to time. You got to keep in mind the newest 7.3 truck is almost 20 years old.
    Will agree with others said about noise, they are loud even with stock exhaust. The automatics behind them were marginal as well for pulling heavy loads. They are capable of being built to handle it but another expense. I've got the six speed manual in my truck.
  • A 7.3 diesel is 444 cubic inches. It is an industrial strength engine, that is slightly overbuilt. It is pretty easy to get the hp over 300 which is plenty. Even with the 4 speed auto it is a good puller. I have 175k miles on mine and the auto trans is fine. The first brake job was at 140 k miles.
    i have rebuilt the front end and the truck still drives like it is supposed to. No reason to sell it.
  • monkey44 wrote:
    Yup, mistyped :( 7.3 RWD for city/rural towing in a small business - no heavy TT or 5'er ... just local 50-100 miles per trip few times a week. Hauling equipment. 134K miles on it ...
    Ad long as you're prepared to keep a 20 year old truck running. Business use, time is money. May be great, may cost you as much as new truck in repairs and downtime.
  • I had the same vehicle. Only reason I sold it was I wanted 4x4. An excellent vehicle . Check my profile to see what I did to it. Trans cooler most important. DP tuner was designed by Ford engineer, works great, Best for the 7.3.
