mbloof
Sep 04, 2020Explorer
Anne11 wrote:
I thought that the F-250 with camper package had the same payload as the 350 - the camper package includes front springs, extra leaf on the rear and a stabilizer. How is the 350 better? Thank you for all of the advice!
As noted the Ford F250 and F350 SRW are basically the same truck with the latter having an extra leaf in the rear and higher rater tires. (maybe a sway bar?)
The "major" difference is the mostly useless GVWR which on the 250 tops out at 10,000 GVWR and the 350 at ~11,500 GVWR.
Door post 'pay load' is based on the mostly useless GVWR.
In any application, watch the rear tire weight ratings. In ether case a decent sized camper loaded ready for camping will weigh close to over the ratings of the stock OEM tires.
On my SRW the truck+camper+gear actual weight (rolled across scales) was within 100lbs of the maximum weight rating of the tires however the stock OEM tires had unexceptable sidewall flex causing unexceptable camper/truck sway so I upgraded to much better rated tires+rims.
YMMV.
- Mark0.
44,066 PostsLatest Activity: Apr 16, 2026
