AnEv942
Nov 28, 2021Nomad
Not a Lance but removing our bumper would be quite involved.
Doubtful this will help, but on off chance similar how ours is attached.
Bumper is bolted at both ends and across top to under side of floor.
Top of bumper has flange across, and ends that fold back along sides of camper rear wings.
I have some wiring going thru, lower jack brackets and muffler bracket that went thru side.
Trim on rear wall that would need to be removed
Top flange
Looking up from underneath at rear top flange bolted to floor/frame, several bolts
On ours rear holding tank cover would need removal for access
This was taken while doing right rear wing wall repairs but shows bumper side wings
And from behind (after repairs)
Again while doing other repairs but shows left bumper side behind camper wall.
How similar your is, if at all, I don't know. Other than removal of our tank cover to expose, believe I could access all the bolts. Need to securely support while unbolting. What I'd need to look at, not having removed, is if any interbolting/ of rear holding tank. Its close and might be some interferance or shared bolting.
Top flange
