Ezlife55's avatar
Ezlife55
2004 2500HD Heated Seats
On the trip down to Yuma last week the heated seats were fine the 1st day. On the 2nd day and subsequently, the driver and passenger seat heat would both go on for perhaps 30 secs and then shut off. A week later they do the same thing........everything else works normally.
Wondering if anyone has had the same problem and could point me to the fix, thanks
  • Thx for the replies....I hope its a short....and easy to find!
  • We had the same issue. When we would hit the seat heat button, the light would come on, and then click off after about 5-10 seconds.
    The shop where I have major work done found out that the wire that carries the current to the seat had started to chafe, and was shorting to ground. The bad spot was on the drivers side. They repaired the bad spot and it's been working ever since.
    Good Luck.
  • here is a another forum regarding your issue.
    http://www.chevytalk.org/fusionbb/showtopic.php?tid/182894/
