thomasmnile
Mar 14, 2016Explorer
Jim2007 wrote:
Hi All: This truck has about 110k. I have done alot of work on the engine and no major work on the auto. transmission. I would like to keep using it as our tow vehicle. I have changed the transmission fluid every 30k as recommended by Dodge. It is my understanding the color of the fluid is about the only indicator of problems in the transmission. Is there other indicators? The shifting between gears is smooth. Thanks for comments. Jim2007
A question: When you perform the fluid changes do you also check and adjust the bands while the pan is off? Think the owners' manual for my '05 recommends it. I know the shop that services mine does at each fluid change. Does your truck have the 47RE or 48RE slushbox?
