poppin_fresh
Jul 11, 2016Explorer
I just sold my 2005 18SB and it didn't have any leaks/soft spots that I was aware of, but I did have to tend to some issues that certainly would have been if I hadn't caught/repaired them.
There are a lot of things in that area that could be the culprit as there is a ton of plumbing things in that general area. It could be:
1. Roof vent caulking for the fridge is shot(eternabonded mine when it started to get sketchy)
2. the drain hose for the fridge no longer drains outside (mine drained on the floor, so I had to turn the pan around and use a catch container to stop it)
3.The city water connection leaks (had to replace mine when I caught it leaking a little)
4.Some other various plumbing fitting is loose/leaking (outside shower, water pump, sink drain, etc.)
