saguaro's avatar
saguaro
2006 Dodge Diesel Pickup Ball Joint Problems
At 45,000 miles I learned the front lower ball joints on this 2006 Dodge diesel pickup were shot and needed to be replaced and about $1,400 later I thought I was good to go. But now, at 63,000 miles I am informed they are "a little loose" and under suspicion once again. After a little research I discovered this is a chronic problem with Dodge pickups 2003 and newer allegedly because "the front end is too heavy". I was just about to purchase a slide-in camper for this truck but can't see any point in doing that if I am going to be buying expensive new ball joints every few years. I have never driven this truck off road or abused it in any way and in fact have been very conscientious about all maintenance. Furthermore I thoroughly trust my mechanic. Is it time to replace this truck, or can someone recommend a more durable fix?
  • Your trusted mechanic might have the best intentions for you and still be off on this one particular item.
  • Another owner with original upper and lower BJ's at 150 K, As others have said,there is some "movement" is these joints that is normal.I have towed heavy and my truck does go off road. Too many mechanics want to replace parts when there are no issues.
  • I replaced my lowers under the carport at 67k miles with Moog ball joints on my '05 Hemi 2500HD 4x2. Must be the massive weight of the big Hemi! I did it myself with loaner tools from Advance Auto Parts. Not an easy job. The originals where clunking and groaning and had a bit of play using the prybar under the lifted wheel method. Any mechanic that told me that was normal, well I did it myself anyhow.
