RICKIM
Oct 01, 2014Explorer III
I had a very slight wander but figured I was still driving a large truck so I dealt with it. What I ended up having more of, was a slight knocking in the steering.
After some research and no dealer help, I started off with a Borgeson steering shaft......didn't fix it, then went to the up-graded 2008 front end track bar, pitman arm and drag link.....didn't fix it......Still knocking and slight wander.
Then went to this, Click.
Steering is much improved as far as tightness and responsiveness, and no wandering.
Heavy duty 1/4" steel. Very stout.
While I had it apart I changed all the sway bar bushings to poly also.
It was well worth the investment, and its a steering upgrade and improvement.
Good Luck,
Rick
Good Luck,
Rick
44,071 PostsLatest Activity: Aug 23, 2026
