sportsman_500
Jan 16, 2015Explorer
I have a 2008 that does exactly as you describe. I installed the same brace as RICKIM and noticed a slight improvement. Previous to that I replaced the tie rod at the pitman arm end which had slight play and had the front end aligned. There is still something not right. I was going to try a new steering stabilizer shock next and after reading here will double check my bushings. I also switched from an off brand of tire to a set of Firestone's. The real problem I have is this slight wander and corrective action I believe is causing my trailer to sway unnecessarily. I have been fighting this problem since I purchased the truck last spring.
