GASA765's avatar
GASA765
2007 Dodge 2500 Water Fuel Separater Question
How often do you drain the water fuel separater?
How much do you drain out?
What kind of damage can occur if its not drained!
Thanks
  • Old-Biscuit wrote:
    When I first bought my '07 I use to check it after every tank of fuel......never found any water.
    After about 6 mos. of checking.....I quit
    I change fuel filter every 2nd oil change and have never found/seen any evidence of water.
    I go thru a lot of fuel.....travel FT and get fuel from all kinds of service stations from all different sources.
    I too have never found any water. I did have the WIF light come on once after a heavy storm, but light went out after a couple of miles so it was probably just some moisture on the sensor.
  • When I first bought my '07 I use to check it after every tank of fuel......never found any water.
  • Every couple thousand miles on my 04.5 (when I remember) Change with every second oil change
    (about 10-12K miles)
    I went too long the last time,the lite went on and draining would not turn it off.Two bottles of HEET did the trick,changed filters at the next stop,along with an early oil change.
  • Sadly not as often as I should.
    Drain until there is no more water.
    Injector failure.
    Do you have the updated fuel filter canister or the original one?
