Ralph_Cramden
Jun 08, 2018Explorer II
If you look closely at the areas around wheel wells on any RV you're more likely than not to find numerous areas that are open to water intrusion, and a lot of times you'll find raw wood be it framing on a stick and tin or the substrate layers on a lam trailer, the edges of the subfloor, etc. At best you'll find a halfassed caulk job where a lot is missed or improperly applied. The RV manufacturers follow the out of sight out of mind method of manufacturing.
