Bert_the_Welder
Apr 10, 2021Explorer II
JimK-NY wrote:
I stand corrected. It appears that the old 855 was a lot lighter than any of the models currently available. Even so that 3275# estimate will turn out to be on the low side. Check this brochure and you will quickly see the weight is for a stripped down model without microwave, without awnings, not even a TV antenna or a stereo.
https://recreationalvehicles.info/2010-alp-eagle-cap-truck-campers/2010-alp-eagle-cap-truck-campers-brochure.pdf
That 3275# estimate is likely to hit a loaded weight, minus passengers, well over 4000# and probably closer to 4500#.
I immediately thought the same. "Eagle Cap? Those are HUGE!" But then I saw it was a comparatively small one to modern units.
If his truck payload is 3800+ as he stated, I'd think he could push up to 4200 and be fine. Maybe some bags and a sway bar. If getting into the 4500+lb range, IMO and experience, it's not worth the blood pressure. My current pair is quite mismatched but the truck with add-ons handles the weight. It's just a 'heads-up' type of driving and gets more tiresome the older I get. LOL! Looking forward to the new dually.
