hinterland
Apr 12, 2021Explorer
JimK-NY wrote:
I stand corrected. It appears that the old 855 was a lot lighter than any of the models currently available. Even so that 3275# estimate will turn out to be on the low side. Check this brochure and you will quickly see the weight is for a stripped down model without microwave, without awnings, not even a TV antenna or a stereo.
https://recreationalvehicles.info/2010-alp-eagle-cap-truck-campers/2010-alp-eagle-cap-truck-campers-brochure.pdf
That 3275# estimate is likely to hit a loaded weight, minus passengers, well over 4000# and probably closer to 4500#.
Looks like the 2008 855 was built before the brand was bought by Adventurer. There is no microwave etc. So, will be watching the weight at the scales. Thank you
