taken
Jul 30, 2015Explorer II
Lynnmor wrote:taken wrote:
To the OP, don't forget, your 250 is identical to a SRW 350 so don't sell it short on capacity. It is de-rated on paper and it's sticker to fill a different market segment but it's parts are all the same. Even it's axles are de-rated on paper but you in fact have the same 7k axles as the SRW 350. You have more truck than you think there...
Well close, depending on options the 350 has heavier springs and thicker spring blocks to make it sit higher. Still, a 250 can be made into a 350 for little cost.
Actually no, the main spring packs are identical between the two. Only an upper overload spring is added to the 350 SRW. The taller blocks don't add capacity. However, both the upper overload and the taller blocks can actually be had on a 250 right from the factory if one orders the camper package on current trucks. So, in fact, a 250 can be ordered to be physically 100% identical to a SRW 350...
Well, except for the fake ratings on the 250's sticker... Those will never be the same...
