rjstractor wrote:
donn0129 wrote:
What transmission? 2500 Cummins are available with both a 6 speed manual and a 6 speed automatic. The 68RFE automatic is a very reliable transmission that will return years of service. Depending on rear end ratio it could be a real good unit. The 3.42 standard rear end ratio works good for most people. But I would much prefer the 3.72 or the 4.10 for towing heavy.
Currently the only axle ratio available with the Cummins in the SRW trucks is 3.42. To get 3.73 or 4.10 you have to go with a DRW 3500.
This is true. From the factory, you can have the gears swapped aftermarket.
