Norskeman's avatar
Norskeman
2011 Duramax - new DEF Tank
Have had the code, P205B, come and go the past 2 weeks. Have a little over 48,000 miles on the truck. One time the truck remote start did not work (truck started and then stopped) - CEL light was on when I entered the truck.
So I monitored the parameters with my Edge Insight CTS.
Urea level - good
Urea range - good
Urea pressure - good
Urea temp - looks like the problem - has been stuck on 114, 116, 120. Today it was stuck on 120 and then cycled between 113 and 120 degrees. Was 40 degrees out and the tank temp never went below 114 degrees - even after sitting outside all night. So it looks like the temperature sensor in the tank is the issue.
I am able to reset the trouble code but it does come back at least every other day.
Took it ti the dealer today and they said the fix is a new DEF tank. All covered under warranty.
