Same springs?
I thought the Ford's F250 had softer springs (vs F350) unless you specified camper package or snow plow prep which gave them stiffer springs. Plus I thought the F350 had the extra overload spring. They always rated the F250 with lower cargo carrying weight rating on their website before.
I am not familiar with the newer ones so maybe that has changed.
Turtle n Peeps wrote:
blofgren wrote:
Me Again wrote:
I just do not understand buying a 250/2500 if one tows a 5th wheel.
x2; there's a pretty good chance of being over GVWR with one.
Same frame, same engine, same tranny, same brakes, same rear end pretty much the same everything. And having a different rear end riser spring block and a sticker on the door doesn't bother me. :B If it did, about 15 minutes worth of work and 50 bucks worth of parts would change that. :)
