Perrysburg_Dodg
Apr 10, 2013Explorer
Do you feel any vibration in the floor? If the torque converter is not balanced correctly that will take out the seal and front pump. The converter is installed on to the transmission before it is mounted to the engine so they should not have cut the new seal. Maybe a cut pump cover o-ring? That would not be hard to do if they tried replacing it hanging from the transmission jack.
Are you sure it's not a line leaking. Where is the puddle of oil, off to the side or in the center of the truck?
Don
Don
