ib516
Apr 13, 2013Explorer II
CANAMKID wrote:
I wonder if by chance you were towing in overdrive. The reason I ask is I had to
replace the pump seal in my 2001 F350 also. Found out thatif you do this the trany
will over heat the oil because there is not enough flow to the cooler.
Apples to oranges. The trans in your 2001 has little in common with a 2011.
The new ones are computer controlled, and generally recommend towing in overdrive with tow/haul activated.
