mdamerell
Dec 13, 2013Explorer
chrsnl05 wrote:mdamerell wrote:
I'd be taking the 13,000# that trailer grosses and finding a truck that can tow say 14,000# by the numbers (guide). In the 2009 model year you are looking at a diesel. Why guess at having enough truck. The V10 taps out around 12,000#.
If you can buy newer 2014 Tow Guide if you found the 4.3 rear you'd b ok (15,000#)but they are probably a special order.
Tow Guides by year
The 09 is what I currently own so
I am not necessary looking for a 09. I found a 2011 f350 ccsb srw but its 5 hours from me. Only asking $23k. The down side is it has 90k miles on it. The miles don't concern me much since its not a daily driver so I won't put many on it
If you click on the tow guide and pull up the 2011's for a 13,000# trailer they are directing you into DRW's unless it's diesel. Then you can do 14,000# on a SRW. If it's just to pull your trailer and not a daily drive why not just get the bigger truck and cover yourself?
Good luck.
44,066 PostsLatest Activity: Jul 25, 2018
