SoCalDesertRid1
Dec 14, 2013Explorer II
Gdetrailer wrote:Haha. No BS about it, kind sir. I know exactly what I'm talking about. Sorry but you picked the wrong guy to go toe to toe with here. Check the ratings on the 18" and 20" tires for yourself. 3195 lb load rating per tire is flat out puny these days on a single rear wheel 1-ton pickup.SoCalDesertRider wrote:I call B.S., you don't know what you are talking about.
The smallest stock tire size also has the lowest load weight capacity. This negatively affects the truck's ability to carry a heavy hitch weight. Better off having a higher rated tire (18" or 20"), with a lower ratio axle (4.30).
My 2013 F250 IS equipped with the smallest tire size FROM FACTORY in 17"
LT245 75R17 Load Range E
That tire is rated at 3195 lbs max cap at 80 PSI
That is 12,780 lbs max tire capacity for the truck.
Take away my trucks weight (5600 lbs)you have 7,180 lbs LEFT OVER for "cargo".
My truck has cargo weight tag of 3,400 lbs.
That gives me 3,780 lbs EXTRA TIRE CAPACITY that I can not "use".
I would highly doubt that even a F350 is going to exceed those tires either....
By the way, my F350SRW has 3750 lbs per tire load rating and I have used every pound of it on the rear axle on that truck (7500 lbs).
44,066 PostsLatest Activity: Jul 25, 2018
