rowekmr's avatar
rowekmr
2011 Ram 2500 6.7L Turbo
The actuator harness/wiring is broken on this so no turbo operation. Dealer said the part is no longer available stand alone you have to order it with new turbo assembly $$$.
Most used ones come without actuator. Any place do quality actuator rebuilds?
This truck has 201k on original turbo so might swap out turbo if I can find a lower mile take out. Which years are compatible with 2011. Is it the same turbo on all 4th Gen?
  • Cummins part, also look on ebay. Used turbos are fairly common on there. Also there are aftermarket turbos available. Go to some of the Cummins forums and look around. Those guys are pretty knowledgable about what fits.
  • I would also check with your local Cummins dealer. When I put an exhaust brake on my 2003, they were far less expensive than the Dodge dealer.
  • Where have you checked besides the dealer? Try rockauto.com or post your question out at the Ram forum or Cummins forum.
