Frozen001's avatar
Frozen001
2012 2500HD CC SB with 6.0L and 3.73 ratio
Hi all,
Took our first long trip with my newer tow vehicle. I went from a 2006 chevy Duramax to a 2012 6.0L gas with the 3.73 ratio. Now I fully understood there would be a difference due to it being a gas so that is not my issue here. But with a 5100lbs dry travel trailer(estimated 6500lbs max loaded) , I am no where near the limits of the truck.
Well like I started off, too our first long trip, Central NY to Maine. Towing on the highway at 65mph it would not shift to 6th gear. Is this typical for this setup? I am strongly considering swapping the gear ratio to the 4.10 depending on the cost.
In 5th gear I got like 8.5mpg which is what I expected, transmission was nice an cool typical temps in the 170-180 range, peaked at 186 climbing the Berkshires on the Mass turnpike, absolute max I seen was 196 when we slowed to a crawl in a traffic jam, but that was maybe 10 minutes.
  • Normal, I always lock out 6th when towing, even in florida. I mainly pull in 5th and sometimes in 4th. Let the 6.0 pull in those gears instead, and when u hit 3 k rpm it really wakes up.....overall a really good engine. No problems pulling the weight that your towing...
  • if towing with tow/haul on 6th gear upshift won't occur until 68MPH. Run it up to 68-70, let it shift and then settle in at 65.
  • The 6.0 barely has enough low end torque to hold 6th unloaded let alone towing 6500lbs. The slightest hill and it will downshift. Leave it in 5th when towing... THat motor needs to rev
  • I have the same truch except a 13. Towing 8500 lbs its in 4th 30% of the time and 5th 70%. Never 6th even downhill.
  • Yep...normal and expected. Just consider 6th gear a grocery getter gear and forget about it while towing.
    A gear swap is an aweful expensive way to feel 6th gear the small percentage that you are towing.
    Thanks,
    Jeremiah
  • I had an 09 like that. Just lock out 6th gear and drive.
