the_bear_II
Feb 13, 2014Explorer
Curb strike knocked the camber off... You indicate alignment can't be the cause, have you had the alignment checked ? I had similar wear and it turned out the factory failed to install cross pieces between the spring shackles which allowed the rear axle to move out of alignment side to side by about an inch.
44,068 PostsLatest Activity: Jun 01, 2026
